How difficult to upgrade the memory ourselves?
The new 2018 Mac mini uses SO-DIMM for memory. From the official pictures, it seems easy to upgrade the memory ourselves, but we hope you folks can help us confirm how difficult it is to upgrade. Thanks!
좋은 질문 입니까?
댓글 16개
for pro person is piece a cake - for someone who unable to hold screwdriver - impossible
Bart 의
was lead to believe you just popped open the bottom and replaced the ram module with another chip of similair specs. but video i just watched doesnt make it seem like you can just “pop it open”. this is the exact reason i bought the mini. and im not going to pay apple 400 euros to add 8gbs of ram to it.
mckcrs 의
I just received my 2018 Mac Mini also and took off the cover and the T6 screws, I saw where the memory cage was though I am not sure what need to be removed to access it. Looking forward to some videos on how to do the ram upgrade. For now I am stuck with 8GB of ram
steve 의
I am writing this on a freshly-upgraded 2018 Mac mini, having just replaced the two 4GB RAM modules with two 16GB modules. I can say that the procedure was quite a bit more complex than I had anticipated, given the photos I had seen of the RAM just sitting there exposed, looking able to just be popped-out of the bottom of the case.
In fact, you will need the right tools AND a bit of careful skill to accomplish this task. Took me less-than an hour.
If you have ever worked on the inside of a prior generation Mac mini … to replace the HDD with an SSD for example … this job is roughly equal in difficulty to that. Beware, there are some *delicate” connectors that you can break if your are not careful in removing them!
James 의
Search Youtube there’s plenty of tutorials available now! Have Fun!
gregbonnier 의
댓글 11개 더보기
