주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
758 질문 전체 보기
MacBook Pro not charging. Solid Green Light
Ok so when I plug in the laptop, the light is green and doesn’t change to orange. When I turn on the computer, the computer says its not charging. Ive already tried a SMC reset already. The battery was left in the computer for about 4 years without use so the battery is probably at 0%.
Sometimes, the light will change to orange, the battery indicator lights will light up, then the light will change green and then the computer will say not charging.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
With a battery unused for such a long time it’s no wonder it doesn’t take charge. First step in my opinion would be to replace battery, that’s probably all you need to do.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
Let’s get a better look at the condition of that battery with a better tool and then we can advise you better. You may have to select an older version than the current one:
How to Test a Mac Laptop Battery
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
jimmysofat6864 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 293
