주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
Display has a vertical band on left side and white screen
I haven’t seen this one before. The left side has a black vertical band and the rest of the screen is white, Customer said the machine was working fine and she woke up to this in the morning. No spills, no drops.
It will generate a picture on an external monitor. I know how to make the external monitor the active screen from the original screen but have forgotten if there is a way to do it if you can’t get to the original display @danj can you help on this one?
UPDATE
very close examination revealed a pin hole size impact
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 1개
선택된 해법
That’s a broken LCD panel. Command+F1 should toggle the screens.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
I'll expand a little on the broken LCD diagnosis, in the bottom right corner of the black band, that jagged corner is a telltale sign of panel damage versus some sort of signal or digital issue.
Joe you were correct. see update to post. It was so small I missed it and I believed my customer.
댓글 달기
답변을 추가하세요
mayer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 17
전체 시간: 2,047
