iMac 27" HDD swap recipe
will this work for sure?
I have a 27" iMac 3.06ghz (late 2009) core 2 duo. The hard drive internal needs upgraded to a higher capacity drive. If I get one of these:
https://www.applecomponents.com/items/00...
And connect any 3.5 7200rpm Sata Hard drive, will I have problems with the fans spinning up? or any other abnormal behavior to look forward to? TIA Jeff
좋은 질문 입니까?
댓글 2개
So, I take it the ifixit has never upgraded the hard drive in this machine then? because that's the impression I'm getting? Jeff
twoapplenuts 의
We have a guide to replace the hard drive that can be found here and information about compatible hard drives can be found here.
Andrew Bookholt 의
