Not sure with your brand but usually auto defrost mode occurs once every 8-12 hours depending on brand so 3 times per 24 hours may be plausible.
If more often than this then it depends on the make and model whether the auto defrost mode is controlled by the defrost timer (if it has one) or the control board (if no separate defrost timer) where the problem may be.
Your comments seem to be being automatically deleted by the ifixit spam robot for some reason.
If you're posting a comment with a "link" attached just try commenting without it or change the wording of your comment so that it will pass through OK
Hi @randbrook ,
What is the model number of the fridge?
jayeff 의
Kenmore 363.9632785. It appears to be going to defrost cycle every 2 or 3 hrs. It gets to 0 & an hour later it is 35.
The Ice in the bin melts and refreezes
in a clump.
Randall Brookshire 의
It wasn't spam. I was trying to respond to jayeff.Myquestion was about a Kenmore 363.9632785 from last night.
jayeff
It's a Kenmore 363.9632785. It appears to be defrosting every couple hours.
It goes to zero. An hour later it's 35
Hi @randbrook ,
jayeff 의
