2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
1073 질문 전체 보기
flashing apple logo after new screen installation
after switching out the new screen, the screen would only display a flashing apple logo. tried restoring and updating and it wouldn’t work.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
There are a few of possibilities here:
  1. It could be a bad replacement screen. Try installing the original screen to see if the problem goes away. If it does, then you probably have a bad replacement screen.
  2. It could be damage to the Home Button or Front Camera Flex. Take a close look at the flexes and connectors, preferably with magnification. If in doubt, just connect the screen alone without the FCAM or HB. The bootup will take longer but once booted, everything else should work.
  3. You have logic board damage. This could be caused by accidental damage during the repair or latent issues that only crop up after repairs and the requisite shutdown and reboot, such as the Audio IC or Baseband. If you have a short bootloop (~10 secs) it’s usually the Baseband IC.
해당 답변은 도움이 되었습니까?
점수 4
의견 추가하세요
귀하의 답변을 추가하십시오
sam sherman 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 30
