tristar compatibility ipad air and iPhone 7 plus
H Everyone
Is 610A3B is suitable for ipad air??
I check the website where is tristar compatibility chart…
But i want a confirmation plz..
@refectio Sir i m tagging u :)
Thanks
좋은 질문 입니까?
H Everyone
Thanks
좋은 질문 입니까?
I personally have used the 610a3b in place of all other versions of tristar and have not had any issues. As long as the replacement Tristar is from the same or more recent version, you should be fine. Just don’t use an older version on a newer device.
I was scolded in the past from using the 610a3b in place of the 1610a1, a2, a3… but never had a problem from it :)
But would always recommend using the original where available. I have done 2 of the Ipad Air over the last couple weeks and both times, changing Tristar would get it to charge while on but not while off or sleeping. Had to replace the PMIC to get it fully charging properly
해당 답변은 도움이 되었습니까?
Yes. The “tristar compatibility chart” is completely wrong. Use 610a3b for all 1610 variants.
해당 답변은 도움이 되었습니까?
@jessabethany thanks a lot
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,106
댓글 1개
@jessabethany Do you know the answer, Mrs. Microsolderer?
Martin 의
