주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
20 질문 전체 보기
Dropped and display screen is different colors with lines how to fix?
I dropped my iphone 3g and the screen is sometimes white and changes colors and has lines at the right side but i can still hear it open and lock and i am able to take pictures. how to i fix it and if i need to replace the lcd how much would it cost?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 20
댓글 10개
did you check connector 1 and do a hard reset? press and hold home and power for 10 seconds then release buttons.... you never know it might work and save you quite a lot of money..
What if your lock button doesnt work?
what if the home button doesn't
work?
I have a question
I was on YouTube and my phone start glitching crazy then different color lines pop up on my phone I try to turn it off and cut it back nothing work HELP PLZ ASAP
Soooooo my phone fell today and it started to blink and some clear lines appeared on the screen. After I hit my phone w/my hand, it the blinking and the lines disappeared. I turned this off for it to "rest" for an hour. When I turned it on, the problem came back and this time nothing fixed it. Aparte from changing the LCD screen, what can I do to fix it. Pllllzz help!Thanks
댓글 5개 더보기
댓글 달기
답변 6개
선택된 해법
If only your lCD is having issues, you can try replacing that:
iPhone 3G Display
If it is both your LCD and your glass/digitizer that are broken, this is the part you would need:
iPhone 3G Display Assembly
The guides for how to do the repairs are linked on the product pages.
Replace the LCD in an iPhone 3G and fix a malfunctioning display. The display is only the internal LCD panel. The front glass digitizer touch screen and the metal backing plate are not included. 이미지
제품
iPhone 3G Display
$29.99
Replace a scratched or cracked front glass panel or a malfunctioning display for your iPhone. 이미지
제품
$59.99
이 답변이 도움이 되었나요?
점수 6
댓글 달기
가장 유용한 답변
I dropped my phone on the concrete and my screen turned colors with lines in it but I can still read words and go on it the screen is just blue what is wrong with it and how much to fix it
이 답변이 도움이 되었나요?
점수 8
댓글 1개:
It's an iPhone 4s
댓글 달기
I dropped my oppo and my screen has gone colourful I need help ASAP please
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I was walking and put my phone in my waist went I take it out it is showing me different colors need help what should I do
댓글 달기
My sister once threw my phone to the ground and apart from all the shattered screen, some colored lines appeared only at the bottom of the phone but it still worked. Then it fell again, and this time, the lines covered the whole screen. So my dad took it to check and they had to change the whole display; so they remove the screen and put a new one.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
So my phone is glitching and it has lines on one side and the whole screen is green and pink so I can’t tell what color are my apps and I don’t know how to fix it. HELP
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I dropped my moms Xperia xa2 Sony phone on my rock and concrete driveway and now the screen is showing colored stripes even tho I still hear the login sound when I login using my fingerprint I want a way to fix it w/o removing the screen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
soccerplayer32489384 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 104,343
