주요 콘텐츠로 건너뛰기
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
182 질문 전체 보기
Is JDS-040 correct replacement for CHU-ZCT2U (or/and FJDS-040)
Controller model: CUH-ZCT2E.
1) Would FJDS -040 work if my current/existing board is JDS -040?
I can mostly found FJDS-040 which seems to be different compared to my JDS-040.
My USB charging port:
FJDS I keep finding on ebay etc.
As you can see board layout is little bit different. Would those FJDS one work?
2) On USB boards I see square with number 1 or 2 (on different board), since both are JDS-040 boards, what those means? In short, can I replace JDS-040 board ignoring those numbers.
Example:
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 2개
선택된 해법
The FJDS-040 is also known as JDS-040 or JDS040 and should be compatible for as long main board controller is a JDM-040 which it will since your original is a JDS-040.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
@oldturkey03 Awesome, glad to hear it! Thanks for the reply and also explaining main board relation, really helps me in future, something to add into personal knowledge bank.
의견 추가하세요
Looks like it is! According to this guide on iFixit though.
DualShock 4 CHU-ZCT2U Charging Port Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Thanks! Any idea are FJDS-040 still suitable ? Have not yet found any reliable source for JDS-040 boards, only see FJDS-040 being available.
@ajcooke01 Thanks for the link! Unfortunately they dont display bottom of the board. I noticed at ebay and amazon which includes these "JDS-040 With 12 Pin" but upon zooming they all read "FJDS-040" instead just "JDS-040". Since boards layouts are slightly different, quite confused if FJDS and JDS is considered as "compatible" with each other.
@coffeeod Well, I guess we are in a bit of a pickle here...
Could you link me to the board(s) you are looking at buying?
@ajcooke01 example when searching for jds-040 on eBay I get these https://www.ebay.com/itm/12-Pin-USB-Char..., when you look at images you noticed it's actually an fjds-040. Comparing that to my posted image (my usb charging port) board layout is indeed different
4에 댓글 더 나타내기
의견 추가하세요
귀하의 답변을 추가하십시오
Michael Schales 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 21
30일 전: 96
전체 시간: 4,742
