주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
578 질문 전체 보기
Installed new A1309 Battery and does not power up by it
I purchased this battery a while ago and lost it. I found it again and decided to try to install as the laptop runs mainly on power cord. After installing the laptop would not start unless plugged into the power cord. It say that no battery is installed and is running on the cord.
Did I purchase the wrong battery? What else could be of issue?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Do you get a orange light on the charger? If yes let it charge for a while as the battery may be dead quite and take a long time to charge from 0%.
의견 추가하세요
Manta(만타) 드라이버 키트
112 bits for every fix.
Upgrade Your Toolbox
Manta(만타) 드라이버 키트
답변 1개
선택된 해법
We can test to see if coconutBattery recognizes the battery. Complete this guide and upload a screenshot of the application window to your question.
Adding images to an existing question
If we get results from coconutBattery that look like this image, the battery is a dud. Replacing it with a new one should do the trick.
iFixit 이미지
안내서
난이도:
아주 쉬움
2 - 5 minutes
Mac Laptop 이미지
안내서
How to Test a Mac Laptop's Battery
난이도:
아주 쉬움
3 - 5 minutes
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
귀하의 답변을 추가하십시오
Pat Meyer 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 66
