메인 콘텐츠로 스킵하기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
1206 질문 전체 보기
HELP! Logic board physical damage
So I bout this iPhone “won’t turn on” figured an easy fix…
tried other options before cracking it open, no luck.
figured a batter would fix, upon breaking it open I find this!!!
Suggestions?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
2개의 답변
선택된 해법
That’s just a scratch, nothing to worry about. Below that black sheathing is a metal shield. It’s there to sink heat from the CPU and conveniently protects the components underneath.
What this does show instead is that someone else was poking around inside the device so it’s hard to say what was and wasn’t done. If the phone won’t turn on, that could be caused by a lot of different things so you may want to start testing and get back to us with more details. The good news is that there doesn’t seem to be any water damage.
I would do the following (in order):
  1. Always try another Lightning cable and charger, preferably Apple original or MFi certified units.
  2. The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  3. Change the battery. The battery is the weakest link in the entire phone and certainly for charger related issues. It is also the easiest thing to replace. Use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows) to test the battery prior to removal. Anything less than 70% of design capacity will require replacement.
  4. If the battery is in good condition, you can use a USB Ammeter to determine if the phone is really drawing current when it says it's charging. If it isn't drawing current, then I would change the Lightning/Charge Port.
  5. If a new battery and charge port still don't resolve the issue, then you either have faulty replacement parts (possible) or a logic board issue.
해당 답변은 도움이 되었습니까?
점수 5
의견 추가하세요
Looks like a possible puncture to the logic board, and exposed the micro-components inside. Replacement logic boards are available thru iFixit, but if you decide to go to an Apple store, it’s not repairable and they’ll have to replace it out of warranty for $400.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I see that’s what I was very afraid of...
I’ve been searching for an image of the black “membrane” cover removed, of course I didn’t take a pic
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Deanbolean 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 32
