I replaced the cracked LCD but the backlight doesn't turn on.
Will replacing the motherboard fix the Surface Pro 3 LCD backlight problem?
좋은 질문 입니까?
좋은 질문 입니까?
It’s possible that your replacement screen is a dud too. Connect your Surface to an external monitor and see if anything shows up.
Sounds like you scored a deal! Now you have spare parts for your surface if something else breaks. Hopefully a motherboard swap solves your problem.
해당 답변은 도움이 되었습니까?
Been there, done that, got the T-Shirt. Screen works in another Pro 3.
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 242
3 Comments
There is a plastic bridge connector part that connects the ribbon cable for the screen to the logic board and has a screw to hold it in.
If that is missing the screen won't connect properly to the board. It's easy to lose that part when you unplug the screen.
Ben 의
I'm well aware of that. The bridge is in place and I can see the display by shining a light on it. It is only the backlight that isn't working. Thanks anyway.
Lew Murray 의
I was going to try replacing the MB but found an entire unit missing only LCD and SSD for about the same cost. Means I will have a lot of small parts available for sale. Lew at lew@lewmur.com Includes a new battery.
Lew Murray 의
