주요 콘텐츠로 건너뛰기
Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
74 질문 전체 보기
Why does the left side of the headphones work inconsistently? ANNOYING
The left side of my Jbl e45 bt do not work most of the time. If i move it around and im lucky it will work but it is inconsistent and annoying. Please help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
@sraj794021
you did not tell us where and what you move around. This could be as simple as replacing the connector or resoldering a wire. sometimes things can be repaired and do not always need to be replaced.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Sounds like the cable and/or headphone plug has a broken connection. Not much you can do other than replace the cable if you can find a new one.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
In my case, I realised if I twisted my right earcup, the audio on the left will start appearing again. I ended up How do I open it up? and realised that if I pushed the white wire inside the headphones into the headband bit, the left side audio starts to work consistently again. So I super-glued that in place, put it back together and all seemed to work. I suspect the portion of the wire that bends when you fold the headphones had failed, and doing what I did forced the conductive material together and also forced another part of the wire to do the bending instead. Not a great solution, but it seems to do the job.
This is actually my second pair of the same headphone, my first pair broke 9 months in so I claimed the warranty. The current pair started to fail in a similar amount of time.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
sukhrag 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 1,306
