iMac 27' broken stand hinge repair
Can I know the best way of to fix a 27” iMac broken stand hinge?
If any one have video content then it will be better.
좋은 질문 입니까?
좋은 질문 입니까?
I hope you are up to this. This is a big project!
There is two parts to the process:
The first part is removing the logic board and the center fan to gain access to the hinge assembly cover so you can replace the hinge assembly. Here’s the process iMac 27" Repair - Removing the Fan and Logic Board
The second part is you also need to remove the foot stand from the outside afterwards! Apple iMac stand removal with lock down and raise with a business card
You’ll need to carefully peel the shielding foil from the hinge cover and remove it to gain access to the hinge screws. Make sure you have a good Torx driver and I use a little toluene to soften the screw seal material around the hinge screws using a cotton swab (Q-Tip) as the screws are hard to get out.
Here is the needed parts:
Only needed if the foot is damaged
해당 답변은 도움이 되었습니까?
Hi Dan, thanks for this. Is there a single set of instructions step by step showing one how to replace the broken hinge mechanism? I see there is a lot of information floating around on different threads, but would appreciate it if there was one single post which takes you through the steps of rectifying this issue in detail... Additionally, where can one purchase this replacement part? Thanks Dan!!
We don't have a guide as I explained in my answer above. It sounds like this is pushing your skills, best to find someone who can do this for you. Look for an independent computer repair person skilled on iMac repairs.
As for the parts, best to use google search, as an example search for: Apple 922-9878 will get you the suppliers of the Hinge Mechanism. Now the tricky part! Try to stick with the Mac part houses vs Amazon/eBay and I use a prepaid bank card to protect my self if I'm unsure who they are.
Forget the Apple parts and fixes, Google this : 27" Silver iMac Broken Hinge Solution
It’s a simple 3D printed contraption that was made to solve that specific and well-known problem. It sells for around 20$ and works like a charm.
I bought mine on Ebay but the link might change / expire over time, still here it is:
해당 답변은 도움이 되었습니까?
Nice … shipping is more than the product … i wonder why not simply send it via snail mail?
해당 답변은 도움이 되었습니까?
Buy this item really cheaply and it is adjustable and cheap
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 3,141
댓글 3개
Can you tell us which model you have Apple altered the design a few times across the different series.
Dan 의
Your model number and serial numbers are on the bottom of the stand. Input the serial number here to find out exactly what you have
https://everymac.com/ultimate-mac-lookup...
mayer 의
Apple iMac A1312 Core i5-2400 | 3.10GHz 8GB 1TB Mid 2011 High Sierra 27"
Patricia Jackson 의
