Audio amplifier has short circuit
Hi,I am repairing an audio power amplifier…I don't see any damaged parts but the light bulb indicates that it has a big short circuit…its peavey cs 2000 power amplifier
pls help
좋은 질문 입니까?
pls help
좋은 질문 입니까?
Make, model and a few pictures of the boards inside would help. You give us little to go on here. In general, with a direct short like this, look at the bridge rectifier being shorted (if there is one) or if this has a switching power supply, check the main transistor (should be on a heatsink).
Update this with the above info and we should be able to provide more detailed suggestions.
해당 답변은 도움이 되었습니까?
I am unable to upload images but its peavey cs 2000 power amplifier
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 1,947
Is your amp repaired??
Mallon Mbewe 의
Hi im roldan from cebu .my question is..what can i do the speaker out is bad tune ( mahina parang short ,)not fully higher tune.im using 1 channel only cause the other channel is broken .
Thank you.
Kuya Reinz Bustillo 의
Hi @Kuya Reinz Bustillo,
What is the make and model number of the amp?
jayeff 의
Ask ko lang po kung na short circuit yung amplifier means madadamay po ba yung speaker ? Salamat po
Michael Geronimo 의
