주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
677 질문 전체 보기
motherboard connector that controls charging
hello I replace my broken digitizer but now the battery won’t charge and the home button won’t work either. I tried another digitizer and its the same. Which connector on the motherboard controls these together? I probably bent or broke pins?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
The charging and home button worked before you replaced the screen? I’ll get the connector pics for you here shortly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
Yes they both worked fine. Thanks Tyler
https://imgur.com/a/807FYc5
Mine are the black circles I drew.
Note that your home button connects to the connector attached to the back of the screen then connects to the smaller connector on the logic board as shown in the photo.
Now I have to ask, did you unplug the battery before you started anything else during the screen repair? Having both of those guys go out at once sounds like something was shorted. Take a look at your home button flex and see if their is any sort of damge to it. Also take a look at the battery connector which sits right below the charge port connector on that image. Maybe take a few photos and put them in the chat, so I can take a look.
Thank you. I thought I did disconnect the battery but I think it was the wrong connector. I'll take a look at the battery connector and post pics if no problem is found. Thanks again Tyler
댓글 달기
귀하의 답변을 추가하세요
Frank 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 95
