주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2191 질문 전체 보기
iPhone 4s bootloops. Can't restore. Error code 3uTools -2
I managed to successfully flash iOS 6 onto an iPhone 4s and it worked fine. I then had to put the back cover on and put a few covers back and when I was doing that, I accidently shorted the battery positive to the case. It was only for a fraction of a second and judging by the location, shouldn't have harmed anything. Even so the battery is pretty much dead anyway. Now onto the strange stuff. When I tried to power it on after this, it was stuck in a short bootloop and wouldn't turn on. I have tried both iTunes and 3uTools to recover the phone but I get error 21 with itunes and error -2 on 3uTools. Any suggestions much appreciated!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개:
Managed to solve this by replacing the battery with my lab power supply. This is definitely a battery-related issue.
Yes, error 21 was associated with battery issues.
댓글 달기
답변 2개
Hi
a repair guy here. As the iphone 4S is pretty sturdy, touching the case with the battery connector should not damage the phone.
And iff I understand your problem correctly it is pretty similar to not having the battery connected at all.
Try to disconnect the battery and see what happens if you put the cable in. It will show the apple logo for a few seconds, than go black and restart.
During an update or booting it there is a moment it needs battery power even with the usb cable connected to the phone.
If if that’s the same as when you have your battery connected, you’ll need to exchange the battery.
If that doesn’t work check the connector soldered to the motherboard. These are known for some wobbly soldering points. You might have damaged them when disconnecting the battery.
Last at thing I can think of, is to test with an new dock connector flex, but that is not something that is usually related to error 21.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I managed to temporarily fix this by powering the iPhone from my lab supply. I've ordered a new battery anyway. As you said, I noticed that it needs the battery during update and just reboots (not going into recovery mode) at some point.
Thanks for your help. You might be helpful in the future!
댓글 달기
Unable to restore iDevice(-2).
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jamiebrowm 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 2,223
