Cat chewed through cable below volume control. Any way to fix this?
Cat chewed through cable below volume control. Any way to fix this ?
좋은 질문 입니까?
좋은 질문 입니까?
You certainly should be able to solder it, but soldering this type of ultra-flexible wire is a bit fiddly. See https://wiki.restarters.net/Headphones for some hints. You will need some form of strain relief so that tension in the cable isn’t borne by the solder joints.
해당 답변은 도움이 되었습니까?
It might be much easier to just buy a new cable:
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 109
댓글 1개
Hi. Maybe you could solder it but it won't be easy.
Csendes Csaba 의
