주요 콘텐츠로 건너뛰기
Repair information, service help, and troubleshooting/diagnostics guides for Bosch refrigerators.
16 질문 전체 보기
Remove Dispenser from Freezer Door on Bosch Refrigerator B20CS80SNS
The water line broke near the hinge in the Freezer door and I need to replace. I removed the face plate of the dispenser, removed the circuit panel, removed plastic cover , removed the 12 screws around the dispenser unit. However the unit will not come out it appears to be still attached somehow. I can’t find any more screws that need to be removed.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
My line broke right under the freezer door where it curves. I tried to pull it out to put a connector on, but it broke off. I wound up getting an elbow from Home Depot where one end was able to be pushed into the water line. The elbow had a connector which I was able to use some tubing to connect to the main water line, but I had to add a reducer connector to the main water line to make it work.
Now my flab in the ice chute is broken and I am trying to get the façade off. I did find one little slot on the bottom left and i used a small screw driver and have the left bottom side off. Going back to get the whole thing off - hope its not too hard.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 91
