Battery only works in Recovery Mode. Mac instantly sleeps in MacOS.
Hi, I have recently replaced the battery in my 2015 MacBook Air and have been having some issues that I can’t find any information about online.
MacOS says ‘Battery Detected: No’, but says the battery health is ‘Normal’.
When I unplug the MagSafe connector, the Mac goes into sleep mode instantly so I can only use it when plugged in. But, I can unplug the MacBook Air when in Recovery Mode and it doesn’t turn off instantly.
The MagSafe 2 status light is always orange.
Different things can happen each time I boot. Sometimes it acts like there is no battery at all, sometimes it says the battery is at 0% and not charging and then sometimes, it says the battery is at 0% and there is no power adapter plugged in.
One more thing that I have noticed is that straight after the startup sound, I can unplug the MacBook Air and it won’t turn off until it almost finishes loading and then it will instantly sleep.
It is a 13” 2015 MacBook Air and the replacement battery is a genuine Apple battery with only 312 cycles.
Hopefully there is a solution for this.
Thanks
Edit:
I have also noticed that even when there is no battery inside of the MacBook, the MagSafe light still turns orange when plugged in like it is charging. Not 100% sure but could it be an IO board issue?
Coconut Battery Screenshot:
Found some random information about my charger and battery. Can this be useful?
좋은 질문 입니까?
댓글 8개
Who's battery did you use?
Dan 의
I bought the battery off of eBay. I made sure it was the right model number and it seems genuine. I have already reset the SMC and NVRAM and it makes no difference.
Jamie Wilson 의
You may have a bad battery here. Once we have the CoconutBattery info we can see what gives.
Dan 의
As you can see the micro controller within the battery is not reporting to SMC class, you need a new battery (you'll need to return your eBay battery and get a replacement).
Dan 의
I reinstalled MacOS Mojave to see if it would fix the issue and when I was in the installer, I could disconnect the charger and the MacBook would stay on. But, when the install finished, it wouldn't boot into the OS unless the charger was plugged in.
Jamie Wilson 의
댓글 3개 더보기
