주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
모델 A1225 / Early 2009 / 2.66, 2.93, 또는 3.06 GHz Core 2 Duo 프로세서
183 질문 전체 보기
What hard disks are compatible with an iMac Intel 24" EMC 2267?
Can I put any 3.5" SATA disk into an iMac Intel 24" EMC 2267, or does this model use the hard disk's builtin temperature monitoring and so need one from the same manufacturer? Will it take a 3TB hard disk? Some sources seem to suggest 2TB is the limit.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 1개
선택된 해법
Here's an excellent article on upgrading your 2009. It also has links to compatible drives: http://www.everymac.com/systems/apple/im...
The problem with changing drives is the thermal sensor. If you stay with the same "brand" of drive there should be no problem. If you change brands, you will need to change to that companies sensor. As far as I know there are three different ones, the Western Digital 922-9225, the Seagate 922-9224 and the Hitachi 922-9223
I don't know about about a three TB drive.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Great research +. Unfortunately your link isn't working, can you please recheck it?
The link is good but EveryMac has been having problems with their server off and on for a week now. I can't even open their home site right now, give it an hour.
Link replaced
의견 추가하세요
귀하의 답변을 추가하십시오
axel 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 7,895
