주요 콘텐츠로 건너뛰기
모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
583 질문 전체 보기
Need one replacement (short) screw for bottom cover?
After upgrading RAM, I was replacing the bottom cover, and one of the short screws went flying. Can you tell me the size, and ideally a source?
I see that iFixit has full screw kits, but they are $60 and out of stock besides.
Thanks,
Tom.
MacBook Pro 15" Unibody (Mid 2010 - Mid 2012) Screw Set 이미지
상품
$49.99
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I may be wrong but suspect it is a 3mm long Phillips screw and expect it's the same thread size as the longer (13mm) screws.
The screws appear to be a M2 thread with a #00 Philips head
EDIT
A quick search of eBay with "macbook screw A1286" shows a few kits for around $20.
HIH
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Richdave: this was very helpful, thanks! I'm pretty sure you are right about the size. I ordered some 3.5mm screws and will provide an update once they arrive.
Thanks again!
How did you make out?
My long-overdue update: the screws I ordered worked fine.
댓글 달기
귀하의 답변을 추가하세요
Tom Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,238
