주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
359 질문 전체 보기
Why is my MacBook Air shutting off with charged battery?
I have a Macbook Air that has recently begun to shut down with a charged battery.
This always occurs just after it’s been closed and in sleep mode for at least a few hours - I open the display, have about 30 seconds of function, then the computer fully shuts down as if the battery is dead.
It will not turn back on unless it is plugged in, and when it does turn back on I see that I have anywhere from 20-50% battery charge.
I have already reset my SMC and it has not helped. It is now occurring every time I pick up my charged mac that has been in SLEEP MODE and open it when it is not plugged in.
My mac has all original parts, I have never had any problems with it prior to this beginning a few weeks ago. Recently updated to Mojave operating system (about 2 weeks prior to this beginning). No other charging issues or operating issues that I’ve noticed.
Thank you for any suggestions you are able to offer!!
Edit: Image added by request
Edit: Battery status after full night of charging with computer off
Edit: Battery status after 30 minutes of being unplugged from charger. Not sure if it’s important, but the charge shown here (~93%) does not match up with the charge noted in the status bar of my computer (98%).
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
1개의 답변
가장 유용한 답변
Lets check the battery install this gem of an app: CoconutBattery and paste a snapshot of the main window here so we can see it too Adding images to an existing question
Update (12/14/2018)
Well, clearly the battery is charging. But the battery is not charged!
Lets give it until the morning plugged in turned off to let it fully charge and then post the swapshot again to see how it looks with the charger still connected. Then disconnect the charger, wait a good half hour and snap a second snapshot and past that one as well (with the charger still disconnected).
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Image added!
의 답변
Ok - will do. Thanks!
의 답변
Updated with the newest battery information!
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Emily Robinson 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 55
