주요 콘텐츠로 건너뛰기
기기 수리 작업 관련 기술에 대하여 알아보십시오.
43 질문 전체 보기
Microphone cuts out when bent at certain angles [Rosewill Nebula GX10]
I bought a Rosewill Nebula GX10 from Newegg for black friday for about $10. It’s been like 2 maybe 3 weeks now and the microphone has stopped functioning. But to be more specific, it stops functioning after I bend the microphone itself on the headset past a certain angle. In the picture, the green area is where I can place the microphone while still receiving feedback . In the red area, the microphone cuts off and I don’t see or hear any audio coming from the mic. I know the problem doesn’t lie with the jack nor the cord as I’ve messed around with different jacks from different computers and oriented the cord in every manner I could think of. Using Windows’ built in audio settings and discord to verify audio input from the mic. Any ideas as to what specifically is the issue before I take apart the headset?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
The microphone itself should have a pair of wires running inside the armature and into the main body of the headphones. Because you are noticing the issue change states as you mechanically manipulate them, I would guess a loose wire or solder point that is pulling into contact when the arm is up, and loses contact when the arm is down.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thanks, I had a feeling that was it. Now to find an entry way into the headset without disassembling the entire thing (if it's possible) :P
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Miguel 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 32
