주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
Green Light turns on in my apple power adaptor. Doesn't charge
So my power adaptor broke 3 months ago so i took another charger and took the magsafe connector and connect it together. it connects and green light turns on but doesn’t charge i tried it with another macbook and it charges.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Sadly, you damaged your charging logic inside your system.
Often times when the MagSafe cord fails it can short out the signal line which then damages the charging logic. Review this Apple T/N to make sure you’ve got the correct MagSafe adapter and the cable & connector are both in good shape. I don’t recommend patching the MagSafe cable as you did here Apple Portables: Troubleshooting MagSafe adapters
As to fixing your problem you’ll need to work up the chain starting with replacing the DC-In Board following this guide MacBook Pro 13" Unibody Late 2011 MagSafe DC-In Board Replacement If that doesn’t change things you’ll need to get someone to fix the logic board.
해당 답변은 도움이 되었습니까?
점수 2
댓글 6개:
Hmmm i just shaved off a bit of plastic from the MagSafe and it works!
The part that connects to the MacBook because it wasn’t getting good connection
Thanks though
@zantheproplayz - Thats why I was recommending you replace the DC-In Board as the plastic can soften up from over heating.
i completely removed the dc in board plastic..
Please get a new one as you don't want a short!
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
Zander Castillon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 61
