My wonderboom makes buzzing and crackling noises when music is playing
I need to get my wonderboom repaired or replaced as it buzzes and makes crackling noises when in use, can someone please help. The exterior is not damaged and there are no dents. I have only been using the wonderboom in the classroom it still looks new even though its approx 11 months old.
좋은 질문 입니까?
I have this problem as well but it seems like no one knows what to do because I don't have any answers on my question as well.
Ashley Noble 의
Is the speaker plugged in?
Persvicx 의
This is an old topic but just in case. I had this problem that was slowly creeping (on and off over a few weeks) until the point where the bass speaker would crack like crazy (when playing low frequency sounds), and found a quick-and-cheap way to fix it.I took it apart and noticed that indeed the problem was the bass speaker.
I could not really fix it (I could not find the source of the problem), but just put a small magnetic screwdriver head (from these cheap Cr-V heads) against the speaker, which is magnetically hold against the diaphragm with the inside magnet. The buzz-sound was gone. The screwdriver head is small enough that you can re-assemble with no problem.
maximelester 의
I know I'm a bit late but I had the same issue. I was scared that my speaker might be broken. But I found out that by resetting the speaker the crackling goes away.
Daniel Erich Fischer 의
