주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
3021 질문 전체 보기
Move apps from an iPhone to another iPhone without iTunes and iCloud
Hi,
I would move two Apps fom my iPhone 4S to another iPhone 4S, but there is a problem: these apps aren’t again on App Store, so also if I use iTunes for restoring a backup, these apps aren’t again on new device (in my case, is another iPhone 4S).
There is a solution about this? Is possible move an app that is on an hard disk of an iPhone to another without iTunes and iCloud? Because I noticed that if the apps that have been removed from App Store can’t be re-installed on another device.
I hope there is a solution, I’ve also Cydia that could help.
Thank you in advance.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
If you installed the App via the App Store you've bought it and you can re-install it to your new iPhone without issue as long as you iOS will support it.
If on the other hand, if you are trying to install it on someone else's iPhone that won't work.
의견 추가하세요
답변 1개
Log into iCloud on the phone without the app and go to AppStore>profile>purchased and find the app even if it has been deleted from AppStore this should still work.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Patrizio Masini 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 14
