주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
719 질문 전체 보기
Replace Broken Screen - Few Questions
Hello,
I want to figure out exactly what I need and need to do to replace a broken screen for an iPhone X. When I check the iFixIt page for iPhone, it shows “screen and digitizer”. So there are two parts. First off, what exactly is the digitizer? From what I understand, that is what gives the iPhone touch capability - is that correct? How do I know if I need to replace just the screen, digitizer, or both? Lastly, is there a big (noticeable) difference if I replace the screen with LCD as opposed to AMOLED?
Thank You!!
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
OPEN ALL THE TABS
RAM Upgrade Kits for Mac
키트 쇼핑하기
Enough RAM
For All The Tabs
키트 쇼핑하기
답변 4개
가장 유용한 답변
there are 3 different replacement screens qualities on the market. aftermarket lcd aftermarket oled and oem refurbished. in my opinion the am lcd is trash and dont waste your money. the am oled is the way to go for price vs quality. its hard to distinguish between am oled and oem oled. just do youself a favor and dont use the lcd.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Firstly when you buy a screen it will come with both the screen and digitizer. Which is fine and you can easily assemble this into the phone, if you replace with a LCD instead of OLED then you will notice a change as the LCD is not as sharp as OLED and the LCD also uses a backlight which OLED does not
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
You CANNOT peel the screen from the front glass or digitizer, this requires professional equipment and still has very high failure rate and bad overall quality no matter how careful you try to be.
From now on ALWAYS treat the front glass, digitizer (if there is a discrete piece of it) and the display as one unit.
I don’t think you can replace the screen with different type. I’ve heard some brands of aftermarket iPhone display panels but I don’t think there is an IPhone X LCD variant.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
for having 43K rep you dont seem to be very experienced in iphone screen repair......you CAN "peel" the glass from the lcd. it does require professional equipment but an experienced refurbisher should have no issue with "high failure rate" or "bad quality" in fact thats how you get the best quality replacement screens.
and there are 3 different quality screens on the market for iphone 10 currently. am lcd, am oled, and oem refurbished.
Actually there are 4 if you include aftermarket TFT iPhone X.
We are talking iPhone X here. You can peel LCD easier, but try your luck on flexible OLED panels, very few refurbishers can easily and reliably refurbish iPhone X screens. It’s super easy to damage the screen during disassembly and vacuum bonding process. Most repair shops only offer intact screen assemblies taken straight from other phones in China, and we are talking about the China where everything is possible here.
의견 추가하세요
if its just the glass that's cracked and everything works as it should then get a replutable company who do a glass only repair/replacement so you keep the original quality. if the OLED is broken then find a good quality replacement (one whole unit).
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Ezra Shiram 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 109
