주요 콘텐츠로 건너뛰기
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 또는 3.6 GHz quad-core i7 프로세서. 2017년 6월 8일 출시.
176 질문 전체 보기
Upgrade with MBP SSD
Hi all,
I have a new iMac Intel 21.5" Retina 4K Display (2017) which is pretty slow. I’d like to upgrade it to an SSD. Now I have an SSD from my old MacBook Pro (Retina, 15-inch, Early 2013) which I want to use for this.
Can I use this SSD using the port as shown in this guide or do I need an adapter to really replace the current HDD like?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Lets clarify a few points This series has two storage ports, a 2.5” SATA port and a PCIe/NVMe blade port.
Now the rub! If you bought a SATA drive’d system your system does not have the needed hardware on the logic board to support the PCIe/NVMe blade drive. Basically, Apple did not populate the logic board with the parts!
For reference: iMac 21.5" 3.0 GHz i5 (4K, Mid-2017)
“*This model has a Serial ATA (6 Gb/s) connector for a 2.5" hard drive. If configured with a Fusion Drive or an SSD at the initial time of system purchase, it also has a PCIe connector, but this connector is not present if the system only is configured with a hard drive.”
So your only option is to swap out your current HDD to a SSD or SSHD. As far as your adapter that won’t work with your MacBook SSD. For reference review this great guide: The Ultimate Guide to Apple’s Proprietary SSDs.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Simon van Thuijl 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 438
