Screws holding the drive won't loosen.
How can I get the screws holding the optical drive out? They seem to be stuck.
좋은 질문 입니까?
좋은 질문 입니까?
Make sure your screwdriver bit fits all the way down into the screw. For tight screws I like this driver because the diameter of the handle is twice the size of standard drivers and allows much more torque to be applied: [연계 제품이 누락 또는 비활성화 됨: IF145-028]
해당 답변은 도움이 되었습니까?
If it stil won't open after changing screw driver simply leave a single drop of Mobil or lubricants type things even you may use kerosene oil too. It will remove all the junk and rust and you will be able to open it easily.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,298
