Guides and repair information for Bose speakers.
163 질문 전체 보기
Why is my Bose Companion 2 Series II power adapter need bend to work?
Hi All!
My Bose Companion 2 Series II works, but the AC adapter connector needs to be bent with a finger right by the port on the speaker to work. I imagine it is a bad connection with the port. Is there a way to repair the port to not require my constant holding it in place?
Merry Christmas!
Thank you in advance!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
1개의 답변
선택된 해법
Hi @picasso ,
It may be a loose connection or a faulty power socket.
Here’s a link to a not very good video that shows how to disassemble the speaker so that access to the interior components is possible.
Once you have access you can inspect the power socket connection to determine what the problem is, i.e. whether it is a loose connection or if the socket itself is faulty (you may have to use an Ohmmeter to prove this) and needs to be replaced.
Here’s a link to just one supplier of replacement sockets.
If the socket is the problem, as I do not know the specifications of the socket, you may have to search further for the correct type if the link doesn’t show the correct one. Be aware that these sockets are very close in diameter, being 2.1mm and 2.5mm, so this makes it awkward when trying to obtain the correct part.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
@jayeff Thank you! It seems to work fine if you put a pen between the power and audio cables. So far so good. Thank you again!
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Paul 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 92
