How to charge with a non apple charger
Charge without a charger
좋은 질문 입니까?
this is not possible.
해당 답변은 도움이 되었습니까?
Let me rephrase that with a different charger not an iPhone charger I've seen people do it I just don't know myself somebody said you could do with a paperclip or something I don't know thank you anyways
I have no idea what method you're talking about, but that sounds very dangerous and likely to short. I'm sure it makes more sense to spend ~$10 on a new charger then over 10 times that getting your phone replaced because you burnt it.
Yes thanks anyway
All you’ll do is damage your iPhone which will be more costly to fix than getting the correct charger for your iPhone to start with!
I use the 12 Watt unit as it’s a lot faster charging and is able to work in Europe 220 Volt outlets and takes different adapter plugs.
해당 답변은 도움이 되었습니까?
If your looking for a way to charge your phone without charging it with an legit Apple cable and plug you can purchase an adapter kit to allow wireless charging. Please see the attached link.
Qi Wireless Charger Receiver Module for iPhone 5 5C 5S 6 6+ plus
I’ve used one in my workshop before they are okay and just about sit under a case without being too present.
해당 답변은 도움이 되었습니까?
This would be a more expensive solution ;-}
Don't forget you'll still need a Qi Wireless Charger as well! Belkin BOOST↑UP Qi Wireless 5W Charging Pad - Black
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 51
