주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
3306 질문 전체 보기
iPhone4 losing wifi signal,
Hello
At me such problem after repair of the top button , wifi the receiver began to accept very badly a signal on distance of 3 meters from a router it absolutely dont work. Replacement wifi the module hasn't helped I think a problem in motherboard. What I can make? (Except replacement Motherboard)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
I'm wondering the same thing. Very rarely do I use WiFI, but I noticed that I'm only getting 1 or 2 bars of signal. Doing a speedtest results in VERRYYYYY poor speeds. Not sure what's wrong. I checked out the parts, and everything seems fine.
I tried the motherboard to put in another enclosure iphone 4, and realized that the problem with wifi is the motherboard
의견 추가하세요
답변 2개
선택된 해법
this is a link to previous answer that has several links to the same problem.. see if any of the answers help. If they do then please mark up those answers and not this one. As this is the same problem I think we should merge it with the others.wifi range very poor after disassembley
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Link provided to an answer +
excellent answer by utilizing previous experiences and links....
의견 추가하세요
Bradley's post and photos are the best at illustrating what the issue is with low WIFI, Bluetooth and I think GPS as well signals. The little linking piece under the top center of the top EMI shield comes loose and separates from the EMI shield. If it is not put properly in place or it is not put back in at all,(I wondered where it went too and looked and looked until I found Bradley's post) the WIFI, et al signals will be weak. This needs to be included in the appropriate place in the Guides that it applies too. There are many posts on weak WIFI, et al signals here. It is not a mystery once you understand Bradley's excellent post.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
fasthans you can put a note on the guide to help others...
Pollytintop, I did just that. I also tried to add a bullet to the Guide, but was denied. I am sure they had a good reason for doing so and I am not complaining or trying to make anyone look bad at all. I note that I do not see any place for "Contact us" other than this forum. I can't find anything else so I am using this as a means to point out this issue to be addressed. I would be willing to rewrite what I submitted to make it acceptable, if someone would let me know what was wrong with what I submitted the first time.
의견 추가하세요
귀하의 답변을 추가하십시오
Rauf 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 21,609
