Sleep sensor problems / Battery connector, possible water spill?
Hi there ifixit-Team,
my macbook stopped functioning properly. Maybe there was a water spill - I'm not sure though, since the water spilled was pretty far away from the notebook and the notebook was turned off for a few days.
Similar to this problem: when I try to boot the computer, it automatically goes into hibernation mode after a few seconds. Each time I press the power button, it will continue the (existing) boot for 3 seconds, then the backlight will be turned off and it goes back to hibernation - I can continue doing this and even get to the desktop.
After a little bit of reading I have removed the Sleep sensor and the battery and the computer works again, but I noticed some strange marks at the contacts of the sleep sensor and a burnt smell. Since a notebook without a battery isn't very practical, this isn't a great solution ...
Here are some photos of the board with the removed battery conector / sleep sensor: #1, #2, #3 close up. To me it seems like one or two of the contacts have molten, since the copper goes over the engraved letters (BAT/S?P SW) ... or is this supposed to look this way?
Is there anything I can do? Should I try to scratch away the copper on the board so the contacts won't be connected to each other?
Thanks for your help!
좋은 질문 입니까?
댓글 1개
Thanks for the advice and the examination of your board, mayer! Since I'm living in Germany, I won't be able to send it to DT&T. I'll try to clean the board from the metal and see what will happen.
Jonas 의
