주요 콘텐츠로 건너뛰기
모델 A1200 with 2.16 또는 2.33 GHz Core 2 Duo 프로세서
111 질문 전체 보기
Why is a flashing question mark on my iMac's screen at startup?
Hello ,
I have the following problem with my iMac 24” 2.33 GHz, 2GB, 500GB HDD.
At startup I get a flashing folder with a question mark. After trying everything I found online with no success,
In Target Disk Mode I was able to access the drive and wipe it off. I have the original install disk, but it doesn’t let me install OS-X, extended hardware test shown 0 errors.
In hardware profile-video it says Graphics: “unknown video”.
Any help would be highly appreciated.
Thanks.
Update (01/04/2019)
I’ve tried this before but it doesn’t boot, I can’t get to disk utility because I receive this message, I restart and nothing happends.
Update (02/15/2019)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
What is your other system's OS you used to inter-connect to your iMac?
Hello Dan,
On my other mac I have El Capitan 10.11.8.
댓글 달기
답변 2개
선택된 답변
The Maximum operating system on your machine is 10.7.5
https://everymac.com/systems/apple/imac/...
Insert your original system installation disk on boot up and hold down the C key.
This should cause it to boot from the optical drive.
Go to the second page of the install program. The tool bar will appear. Go to the pull down menu to Disk Utilities.
Reformat the internal drive GUID MacOSX Extended. Now go back to the install program and install your system.
UPDATE 2/11/19
Try installing your system in Target Mode if it won’t boot from the original system DVD. Also if it won’t boot from the DVD you may have other issues such as bad capacitors. Check the capacitors (cans) on the logic board. You are looking for swelling and/or corrosion on the tops.
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
I’ve tried this before but it doesn’t boot, I can’t get to disk utility because I receive the message that I need to restart the computer, I restart and nothing happends.
Are you booting from the Installation DVD?
I've tried with the installation DVD holding down the C key, it doesn't boot , it tells me that I need to restart the computer.
Could it be that the hard disk is fried?
As an update , I've borrowed an SSD from a friend ,just to see if anything changes, I need to mention that it was windows formated , I don't know if it matters, the thing is nothing changed.Then I thought I shoud also try to change SATA data cable , so I borrowed one (my question here is , the SATA cable does it need to be apple specific or any SATA would work?), anyway ,again no changes.
Here are some pictures with the capacitors, they don't show any leaks, or swellings.Although in one of the pictures some foam or glue could be seen next to those copper parts, I don't know if it means anything.
댓글 달기
@george72 - I think you need to find someone locally who can help you.
I would double check the OS-X version you are trying to use this system can’t run anything newer than Lion 10.7.5 within a system which has at least 2 GB of RAM.
Windows based drives won’t work in your system, your friends SSD would need to be reformatted and have the Mac OS installed on to it to be useful before installing.
I still have an external FireWire drive setup with Lion to get around the optical drive. If you have an external drive you could try that. using your second Mac to set it up.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
GEORGE 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 477
