주요 콘텐츠로 건너뛰기
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
197 질문 전체 보기
Standby flashes, backlight flickers, repeat every 10 seconds
This isn’t my exact model, but I have one that is extremely similar. When I plug the TV in, it it immediately tries turning on, the standby light blinks and the backlight kicks on, changes the brightness a couple times, then turns off. This cycle repeats indefinitely, without pressing a power button on either the TV or remote.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Cody Mort  we will need to know your exact model number. If it turns on when you plug it is then it is most likely the button bar/IR board or the power board. Remove the back of your TV and take a good look at all the boards. Check for obviously damaged components like leaking/domed looking capacitors and IC’s that are partially melted etc. Post some pictures of your boards with your question so that we can see what you see. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Cody Mort 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 327
