Brand New OWC SSD Not Detected, Old SSD Corrupted
Apple Repair said the factory installed SSD (Samsung) was unrepairable and would cost $1900 to replace. I purchased a new 256gb OWC Aura SSD for $220 from ifixit.com (I live in New Zealand so shipping is a little more).
I installed the new drive into the 2014 Macbook Pro Retina and it is not detected in the Recovery menu (after holding CMD + R on startup).
- Is not visible in the menu in Disk Utility from Recovery Menu.
- I made a bootable HD using an old USB2.0 drive and tried to find it using Disc Utility, is not visible
- Checked the ‘Show All Devices’ in Disk Utility, volume or drive is not able to be detected, it only shows the recovery partition.
Is it possible there is a problem with the logic board on the 2014 Macbook Pro? That the logic board is not talking properly with the SSD?
Update (02/28/2021)
Here are some board and socket images
And the new memory
And the old memory
좋은 질문 입니까?
2 댓글
Dis you follow the OWC instructions?
Remember! Your system needed to be running High Sierra or newer BEFORE you can install the OWC SSD. As your systems firmware needs to be running the newer firmware which the OS installer will put on doing the OS upgrades from Hgh Sierra and newer.
Did you try contacting OWC support to see what they say?
Dan 의
What OWC instructions? I follow theiFixit instructrions. OWC does not send any instructions.
And I don't think you can install High Sierra on the SSD before you install - or you need some specially configured mac or adpater box? The internet recovery only provides Yosemite.
I didn't know you could contact OWC support - thank you, I wil try them.
Kingi Gilbert 의
