주요 콘텐츠로 건너뛰기
어느 범주에도 속하지 않는 기타 제품
251 질문 전체 보기
USB drive won't fit into previously used USB ports
my USB drive will not fit into any of the ports that's it usually in... I just had it in my laptop this morning, and when I got to work it no longer goes into any ports on my work computer. I've already used these computers with my USB many times so I'm guessing maybe the USB has been damaged?? If so, is there ANY way to get my files off of it??
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
You’ll have to closely inspect both the USB port on your computer and on the USB Drive as one (or both) of them is physically damaged. If the USB drive is damaged, then someone who does micro-soldering repair should be able to repair the port.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Check the USB drive’s port for obstructions. Lint, paper pieces, small dirt or other things may cause it to not insert completely.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Tami B 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 56
전체 시간: 9,941
