주요 콘텐츠로 건너뛰기
Repair information and support for the Samsung Notebook Series 9 15" laptop. Released in 2012. Model number: NP900X5L-K02US.
6 질문 전체 보기
I´ve a vertical white line in the screen that appear after my lapt hit
Hi Guys
My laptop was running out of thermal past and because I have it always on at home but I don´t use it very often, I didn´t realize about it, I only saw it one day that it just turned off running super hot.
I´ve open it, I put thermal past in the CPU and it works very well again, except for one very samall detail, a white small line appear in the screen and I´m not sure how to solve it, because I´m afraid that the display is fine, but eigther a connector or the video card can be damaged due to the high temperature.
I appreciate any help.
Thanks,
Mauro.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi @mruizdia ,
Connect an external monitor to the laptop and check if its' display is OK.
(even a TV can be an external monitor if you have the correct cable and the TV has the appropriate inputs)
If it is OK then the GPU is OK and the problem is either with the LVDS cable or the LCD panel.
You did disconnect the battery after you opened up the laptop and before you worked on the repair, didn't you?
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
The video chip may have a bad solder connection. Take a fine magnifying glass to it, and check for blackened or corroded contacts. If there are any, clean it off, use flux and a nice hot soldering iron, and apply a little solder to it. The LCD connector may also be faulty. Check on that too.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Mauro Ruiz Diaz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 768
