Can I upgrade the AirPort board to 802.11ac
I'd be interested as to if there is a card compatible with my mid2012 non-retina 15 inch MBP. I'm getting conflicting answers here and there so is there? and if so whats a good part number?
좋은 질문 입니까?
좋은 질문 입니까?
amimzino
Here’s the problem your 2012 13” MacBook Pro uses a Broadcom board that has a surface mount connection
The newer 8.2.11ac boards have an edge connector
Which is why there is no means to upgrade the AirPort board and the dimensions are very different too. Even if you tried to replace the carrier and the cable it won’t fit the hollow (and the line assignments are also different)
해당 답변은 도움이 되었습니까?
But mines a 15 not a 13. Last unibody made. It’s almost identical to the retina. Save for the retina screen and having an optical drive. I believe it uses an edge connector but I’m not sure.
Same answer Sorry ;-{
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 89
