thm700r4 transmission will not propel in either direction
vehicle will not move
좋은 질문 입니까?
First check to make sure you have fluid in the tranny and that it is clear. If so you may have a bad modulator. If not you can try adding fluid and look for leaks. You should also check that the gear selector is moving when you move the shift lever. At this point I would recommend taking it to a professional---big bucks--sorry.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 806
