주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
295 질문 전체 보기
Why wont my iPad turn on?
  1. My iPad wont start, I’ve tried different methods to restart it such as pluging it in till a computer with iTunes but it wont get recognised. When charging the iPad gets hot in the higher parts of the right side. I would be happy to get help with what parts could be damaged and what to do.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개:
Connect your iPad to the computer and enter DFU mode by press/hold home button and lock button for 5-8 seconds, then release lock button while keep holding home button, after a few seconds you should get a prompt in iTunes - try restore iPad in DFU mode and see it can solve the issue.
I've tried that. But thanks anyway!
댓글 달기
답변 1개
Well it could be a number of things first thing that comes to mind is that when you say it heats up is it when its on? Also do you see any icon or anything on the screen at start? If you don’t see anything on your ipad air it could most likely be a backlight which has gone out and may need to be replaced and since it heats up it may need a new battery since it shows symptoms of failing.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks for the answer! No I can't see anything other than that it heats up att one spot while charging.
댓글 달기
귀하의 답변을 추가하세요
Jonas Björs 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 90
