주요 콘텐츠로 건너뛰기
A1708/EMC 3164 — 2017년 6월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다.
563 질문 전체 보기
Bent display lid from fall
Hi everyone
I just dropped my brand new MacBook Pro. The display lid is bent in the corner! :(
How can I fix this any ideas?
I already tried this but it didnt work :( Macbook Hinge Scraping / Scratching Problem - Quick and Easy Fix!
Thanks everyone.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 6개
가장 유용한 답변
you don't want to risk that lcd for just trying to unbend.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Actually youre right i dont want. But if is there any quick solution i would give it shot. Im glad screen work perfectly except that light.
The light in the corner is caused by the compression of the LCD panels as the liquid crystal material is being squeezed.
Can use like this or should i change panel immediately?
댓글 달기
Many a sin can be covered over using a good protective case. I really like these:
https://www.ebay.com/itm/Rubberized-Hard...
If you just can’t stand it, you can get one from PowerBook Medic for $650
http://www.powerbookmedic.com/MacBook-Pr...
I will be listing this part (a working pull) on eBay tomorrow for just under $500.
Pricey isn’t it!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I ordered one protective case. I hope it will fit to my bended screen.
Thanks.
댓글 달기
The problem you face here is any reshaping of the lid frame puts the screen at risk of damage. The only solution is to replace the lid assembly which is quite expensive!
Sorry ;-{
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
I would live with it
Ill do the same. Thank you.
Did the yellow discoloring worsen over time?? I dropped mine today and have the EXACT same issue :( fixing it will cost the same amount i bought my laptop for and wanna know if i can leave it how it is without it getting completely messed up.
댓글 달기
@fredy12 Did you got repaired ? because I am having the same issue
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Accidentally hit the top left of my laptop screen onto a chair. Bent but no damage to screen. Only the screen has bright spots. ;(
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have this problem right now with my MacBook air m1. Did you ever get it repaired/ did it end up causing further problems?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ferdi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 28
전체 시간: 4,754
