주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Touch ID not working but said it does.
So, odd phenomena here. The home button is fully functional. The fingerprint scanner worked fine until recently. I highly doubt it’s a hardware issue. The Touch ID sensor can be “used” it lets you try and add a fingerprint/unlock with fingerprint, but doesn’t register when placed. Phone was updated, hard reset several times, Touch ID was turned off reset then turned on. Still no luck. Tells you to place finger nothing happens. If it had the “unable to activate Touch ID” then I would know it’s broken, but it doesn’t say that. It will let you go through the process but not register. The next logical step would be to do a full wipe. But was looking to see if anyone had any bright ideas before I do so.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Probably the MESA Boost voltage failed, therefore the logical part of the Touch ID chip is working, communication is working but it can’t sense any fingerprint contacts, which explains the silent failure rather than saying “Unable to activate TouchID”.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Never met a board repair specialist who would repair that, too much work even for them. Plus the backlight is fine, wouldn’t that affect the backlight as well? Still I’m not quite sure.
댓글 달기
귀하의 답변을 추가하세요
Avais Gilani 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 62
