주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
619 질문 전체 보기
Back glass removal advice
Hi all
In need of the back glass cover on a iphone 8 replacing, is it worth just replacing the whole back housing that comes complete with back glass cover, as I have seen it is a nightmare to remove just the glass.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
Found that if not in a rush to remove the broken back glass is to leave it in a sealed container of Isopropyl for about two weeks which acts like a adhesive remover, glass came away a lot easier with this method.
의견 추가하세요
답변 3개
가장 유용한 답변
Sadly you do need to replace the entire case for a cracked glass back
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
its easier for a diy project to replace the whole casing but its very doable to replace just the glass.
remove everything out of the phone, heat it to between 250-300 degC and use an isessamo to scrape the glass out.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Hi Chis, I am trying to replace the positioning ring on the iphone 8, do you know how to install it when it has no adhesive?
의견 추가하세요
You can just change only back glass with laser back glass removal machine
The laser machine will damage the glue between glass and frame, then its easy to remove the glass.
And you also can buy back glass with bigger camera hole, then no need to remove original camera frame.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Thank you for contributing to the Answers Forum. However, the site owners don't want folks linking/advertising their products/services directly in answers or comments. It is advised that you put your contact and business offerings in your profile and link people back to it.
The moderators thank you!
@mayer @oldturkey03 @danj @jayeff
의견 추가하세요
귀하의 답변을 추가하십시오
colin 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 449
