주요 콘텐츠로 건너뛰기
HD action camera with touchscreen LCD, released October 5, 2014.
87 질문 전체 보기
Gopro only works if in the freezer! Hahaha
Gopro in the freezer is the only way I can get it to work. But it only works until it warms up. I replaced the image sensor and it still does it. I tried putting only the battery in the freezer and nothing. Somehow the freezer if fixing it but only for like 2 minutes. Please help. Thank you so much!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Might be a solder connection that has gone bad. As metal expands and contracts in heat and cold, the difference in temperature could cause a solder joint to get a good connection when cold, and loose the connection when hot. Inspect the board with a magnifying glass for any obvious faults. Using a hot air gun you could try to reflow all the solder joins on the PCB. Hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Angela Poston 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 167
