메인 컨텐츠로 가기
일반적으로 통합 스크린을 포함하지 않은 이동하지 않는 컴퓨터입니다.
1168 질문 전체 보기
Can I take my hard drive from my old pc and put it in my new pc?
Hello,
I am upgrading to a better computer and I was wanting to know if I could take the hard drive from my old pc(hp) and put it in the new pc(dell). The problem is, the HP has an AMD cpu, whereas the dell has an intel cpu.
The hard drive itself is a decent one, it is a Western Digital blue 1TB WD10EZEX, fast little drive.
The only problems I could see happening are driver issues, but I have driver install/repair software that works well.
So my question is, will this work or not?
**Note, this will not be permanant, I only plan to run this setup untill I have enough money to buy a new HDD and SSD.**
Update 1/27/19
I just tried this today, and it did not work!!. The computer turned on and everything, but there was no display and it seems to have failed to detect the wifi module because it would not come online on teamviewer, so I wasnt able to go in and remotely fix the problem.
What do I do now?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
코멘트 추가
안드로이드 수리 키트
새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
지금 장보기
안드로이드 수리 키트
지금 장보기
1개의 답변
가장 유용한 답변
You should have no problems as long as the old drive a an SATA rather than an IDE. In other words, if the connectors are the same you are OK.
이 답글이 도움이 되었나요?
점수 1
댓글:
So there shouldn't be any issue with switching to an entirely different processor? Also, both pcs use sata connectors.
의 답변
I just posted an update, more or less it did not work at all.
의 답변
Programs like Acronis True Image have their universal mode which automatically updates drivers during first boot up on a "new" system.
I've successfully used it many times.
의 답변
코멘트 추가
답변 추가
Connor 이(가) 영원히 고마워 할 것입니다.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 56
