주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone 6 Logic board not booting. DCPS shows 200 mA draw
Slightly water damaged iphone 6 totally dead.
removed the logic board, all the shields, & cleaned in ultrasonic solution branson EC, …
Found no shorts anywhere( vcc main, pp_cpu, pp_gpu, var, sdram, …). Also all the rails’ voltages seem to be in range.
Connected the Logic board only to DCPS. It does not even boot but draws 200 mA.
PMIC gets warm but not hot.
help would be appreciated!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Did you check ALL of the PMIC outputs or just the main ones? A faulty subsystem can pull the whole system down as well and it is often overlooked. If they all check out, then check the main subsystems that aren’t powered by the PMIc, such as MESA,CHESTNUT, BACKLIGHT. Then check the I2C lines to insure they are balanced and within range and take a look at the PMIC Reset lines (those that can be probed) to see if the problem is there.
Finally, check the BBPMU outputs as well as a damaged BB system will impede the phone from booting.
Also, what areas of the board were more corroded, that could give you some clues about where the damage actually is.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Update:
PP 1V8 SDRAM rail reads 0.52 V
Check that power rail with the phone unpowered in diode mode to see what reading you get. There may be a partial short that you will need to elucidate.
Found the shorts:
Backlight driver —> 0.18 A
U5302_RF —> 0.02 A
Both are removed.
No booting ( from zero goes to 0.12 A & repeat itself)
DFU recovery on iTune recognizes the board but haven’t gone farther. (Did not recover). Trying not to loose data.
PP 1V8 SDRAM. Ow reads correctly 1.8
댓글 달기
가장 유용한 답변
Does it show 200ma when dcps is connected or after button press. If it's after button press I would check tristar
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
It draws 200 mA before pressing the button.
After button press just a blip & stays on 200 mA.
Could it be a faulty PMIC?
Before removing the pmic remove Tristar and then see what it does on dc
댓글 달기
귀하의 답변을 추가하세요
Hama 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 373
