2.16 또는 2.33 GHz Core 2 Duo 프로세서
322 질문 전체 보기
fans turns constantly 6000 rpm
Yesterday i repair my MBP ( Nvidia Graphic Chip ).
Now he is running but the fans turns constantly 6000 rpm.
it may be that I forgot to connect a cable?
The temp sensors work correctly according to istate pro.
Please help me
ps. sorry for my bad english :)
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
Please explain about repairing your Nvidia chip. Did Apple do this as a recall?
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
3개의 답변
선택된 해법
You haven't given much information to go by, including the readings from iStat.
You may have a process such as a stuck print job causing your processor to run in excess. To find the process: From the terminal type top -u -s3 (to take samples every 3 seconds) and look at the output. This will give you the PID of the offending process. Write down/remember the PID. In the terminal you then enter kill -9 PID number. For example
kill -9 1111
This will kill the process 1111.
Also please tell us the process you used to reset the SMC.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
MBP is running.I forgot the temp sensor cabel under the right fan.... Thank @ all
의 답변
의견 추가하세요
SMC reset would be a good start
THIS LINK should hekp
해당 답변은 도움이 되었습니까?
점수 2
댓글:
I already made smc reset.did not function
의 답변
의견 추가하세요
You may need to disassemble and clean your heat sinks. When they get loaded with dust and dreck your laptop will run hot. I need to do it every two years or so on mine.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Michael 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 1,422
