Screen screw damaged, cant get the screw off
Hi does anyone have any advice on how to remove a screw that keeps the screen in place if the screw head is completely damaged and I cant get any of my screw drivers to catch to unscrew it?
좋은 질문 입니까?
좋은 질문 입니까?
Are you referring to the pentalobe screws on the bottom of the housing (on ether side of the charge port)?
If you’re screwdriver has no grip , you could try to put a stretched-out rubber band between the two or set it with epoxy. If the screwdriver has a bit of grip, then try gently prying the screen upward while trying to unscrew.
해당 답변은 도움이 되었습니까?
Sorry I dont understand your solution?, do you have a video?
the screw driver has no grip at all...
what type of epoxy are you referring to is it epoxy resin or glue, also how do i apply it, do i do it with the screw driver bonded to the screw???
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 68
